Results 1 to 2 of 2
Thread: N80 purge valve and O2 sensor question..
    Feb 2013
    VIC
    Hi Folks,
    After getting the timing belt done, my wife's little Mk4 Golf hasnt been the same. Fortunately I have a Ross-Tech cable so hooked it up and found the following:
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    VIN: XXXXXXXXXXXXXXXXX Mileage: 113790km/70705miles
    Address 01: Engine Labels: 06A-906-018-AQY.lbl
    Part No: 06A 906 018 GP
    Component: 2.0l R4/2V MOTR HS V01
    Coding: 00031
    Shop #: WSC 30079
    VCID: 76E9D64952976BA80B9
    2 Faults Found:
    16518 - Oxygen (Lambda) Sensor B1 S1
    P0134 - 35-00 - No Activity
    17834 - EVAP Purge Valve (N80)
    P1426 - 35-00 - Open Circuit
    Readiness: 0000 0000
    So, I've found the O2 sensor, not sure what "No Activity" means, but I presume this is a replacement job.
    The piece I'm foggy on is the N80 purge valve, where is this ? ... open circut to me sounds like its just not plugged in.
    Any tips where to look ? any chance there's a DIY or how-to ?
    Feb 2013
    VIC
    So, as an update, I found the N80, the plug wasnt sitting on properly and found a heap of rubber goo inside the connector ?!
    After cleaning it up, the connector was not damaged at all, and I simply plugged it in.
    After clearing the codes, drove the car around for a bit and it looks like that one is clear, but the O2 has come back. So I'm phoning around now looking for a part.
    BOSCH Universal = $162 <-- Online part shop
    BOSCH Genuine = $210 <-- Bursons
    OEM From VW = $286.65 <-- VW Dealer
    Ho-hum, what to do ...
