With the N75 not working, you are running off the actuator alone which would be set at about 7PSI of boost.
If you look in the front of that connector you will see the pins. If you poke a jewellers screwdriver or something like that down the gap. You should be able to push the pin out the back. Then you can get a wire on it again.
thats what it looks like, so you reckon if i push those metal bits hard enough, it should come out the other side?
