The tune has never worked with an n75 running, only an mbc which in a way is only a manual boost request. Not ecu based.
If I can hold 15psi with an mbc I don't have a spongey wg or boost leak .
I'll try increase the wg as suggested
'02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
yes gav, essentially shortened the rod, which in turn starts to open the exhaust valve.
Makes no sense to me either.. I might contact the tuner... bit of a pain in the arse tho (long story).
yes, Viezu tune. approx 12 months ago (current owner).
Shortening the rod should not be opening the wastegate, it should be pulling it closed harder. Preventing gas bypass and providing more drive to the hot wheel.
You should have more thread showing at the end of the rod.
I am away from home now or I'd take some pictures for you.
Yes, more rod showing, nuts moved from drivers to passenger side.
