Results 31 to 36 of 36
Thread: N75 or wastegate
  1. #31
    Aug 2011
    melbourne
    I've considered running the n75 and mbc in parallel...
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
  2. #32
    Quote Originally Posted by leighaus View Post
    yes gav, essentially shortened the rod, which in turn starts to open the exhaust valve.
    Shortening the rod should not be opening the wastegate, it should be pulling it closed harder. Preventing gas bypass and providing more drive to the hot wheel.
    You should have more thread showing at the end of the rod.
    I am away from home now or I'd take some pictures for you.
  3. #33
    Aug 2011
    melbourne
    Yes, more rod showing, nuts moved from drivers to passenger side.
  4. #34
    Aug 2011
    melbourne
    servicing my car yesterday i decided just for the hell of it to wind the nuts even further on the WG actuator, even though i had done at least 10 turns with 0 change.
    Its now boosting to 10psi, holding for a second, then continuing onto 16 psi quite happily. Out on the open road in 3rd and 4th, I'm hitting 19 psi as the tune was supposed to.
    For the actuator rod to be so close to the end, its basically stuffed. I have a forge replacement, so thats my next job. Really strange how it was making no difference the whole time i was adjusting it...
    I can smile again.
    Whilst servicing, i noticed a bit of carbon build up and a tiny bit of oil in the spark plugs, so i'll be doing a rocker gasket / coilpack gasket swap with my mate, and whilst at it doing the cam guide thing... Is there anything else you should be doing whilst on this job?
  5. #35
    Jan 2011
    Gold Coast, QLD
    Out of curiosity, did you install the forge actuator and it solved your problems? I noticed you had it for sale a while back, so was unsure if you ended up installing it.
  6. #36
    Aug 2011
    melbourne
    still on my to do list... its kind of a bitch of a job.
