Results 21 to 30 of 36
Thread: N75 or wastegate
  1. #21
    Aug 2011
    melbourne
    hmm.. maybe my tuner doesnt know his arse from his elbow and got confused... im guessing im hitting the cut from the tune then.. ill leave it as is with the MBC as it runs quite nicely. I fully disconnected the N75 and got no CEL or limp and its even running a bit smoother.
    So im pretty happy knowing that bug racer. cheers.
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
  2. #22
    Aug 2011
    melbourne
    After running a mbc for ages on 15psi ( any higher caused spikes and boost cut) I got super sick of the surging and part throttle issues.. ordered a vanilla n75 from ecs. Installed it ...... Back to 9 psi.. I want expecting that. Given I thought the n75j was incompatible and my old n75 had died..
    More investigating required i guess... unplugging the new N75 with it all still plumbed still yields 5.5ish psi.
  3. #23
    Aug 2011
    melbourne
    after reading this : Golf not making full boost
    im starting to think maybe i have a bad tune?
  4. #24
    Quote Originally Posted by leighaus View Post
    Adjust the actuator up so it makes a touch over 6PSI and see what happens. Assuming that you are convinced that there's no boost leaks at all.
    I am doubting the tune is your problem. Software can't change over time, inputs and hardware may.
  5. #25
    Aug 2011
    melbourne
    The tune has never worked with an n75 running, only an mbc which in a way is only a manual boost request. Not ecu based.
    If I can hold 15psi with an mbc I don't have a spongey wg or boost leak .
    I'll try increase the wg as suggested
  6. #26
    Don't go silly, 2 turns will be plenty.
  7. #27
    Aug 2011
    melbourne
    Made 0 difference gav.... The front nut is only may 3-4 threads from the end of the thread in the wg end.
  8. #28
    So you effectively shortened the rod, correct? Wound the nut closest to the canister closer first. Then the one on the end to lock it up again.
    There's no way if you did this, there'd be no change. I can't think of an explanation why that would be. it doesn't make sense to me.
    gavin
  9. #29
    Apr 2006
    VW Race HQ - Sydney
    Do you even have a tune ?
    You can raise the boost to the turbo limits with a MBC .
    Only issue is as you raise it the ECU throws more fuel in .
    Bug_racer supports the rebellion of the euro revolution
  10. #30
    Aug 2011
    melbourne
    gavin
    yes gav, essentially shortened the rod, which in turn starts to open the exhaust valve.
    Makes no sense to me either.. I might contact the tuner... bit of a pain in the arse tho (long story).
    Quote Originally Posted by Bug_racer View Post
    yes, Viezu tune. approx 12 months ago (current owner).
