Hi,
I just got my V6 Bora back from the panel beaters yesterday, after someone hit my car in the rear last week. Driving to work today, I'm getting traction control alert's and then a EPC light comes on and off.
I get to work, turn it off then on, and the EPC light is still on but the ESP warning is off.
How much bad luck is that??
If you can't get the fault codes read - check under the rear differential, at the back, there are two wires that you will see and a connector plug (attached to a little bracket on the rear of the diff) - check its not unplugged or damaged - thats the wires that control the Haldex unit. having it disconnected means you are 2wd - the lights you show sound like that![]()
