sounds like your secondary air pump hose has come off. in that area where you were looking there should be a black plastic unit. quite big and held on with 3 ten mm nuts. you need to check both ends of this unit as the pipes get slack after time and fall off sometimes just need to be refitted... if you cant find the pump look for the engine air filter.. on the airbox itself there should be the main intake to the engine and then you will see another about 3cm wide. this is the secondary air hose from the filter to the pump. that might even be the part disconnected... if not follow that pipe towards the engine and you will locate the pump unit... make sure they are all fitted ok then try a cold start of your car... ....VDUB...
