Results 1 to 10 of 12
Thread: Multi Function Display
    Oct 2013
    Buderim Qld
    Hi, I would appreciate some help with information about the MFD of Mk4 GTI as it has gone red for some reason. I don't know anything about this area except I have cleared Service Now but that is all.
    Kind regards
    Woodgrub
    is it red all the time?
    often when the dash/interior gets hot they can loose pixels so it becomes no longer readable?
    on the end of the stalk is an up and down button, does toggling that help?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Oct 2013
    Buderim Qld
    Hi Dylan, At first, a few months ago it would come and go, now it is red all the time.I will try toggling to see if that helps. I have been told by VW that it requires replacing. I was hoping I might be able to get that part but I have been told I have to replace the instrument cluster.
    Thanks for your help,
    Kind regards
    Woodgrub
    Hmmmm do a bit of Google searching. I'm sure Iv seen info on replacing just the screen and also ways to repair/clean it in some cases.
    Then again, a second hand cluster could be a cheaper quicker alternative
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2011
    Inner West, NSW
    There are repair guys that will replace just the LCD screen - mine on the S3 was dead and for $80, got it replaced and it works perfectly now
    Oct 2013
    Buderim Qld
    Hi drucejnr, I would appreciate more details about where to get it repaired if possible.
    Kind regards
    Woodgrub
    Oct 2013
    Buderim Qld
    Hi Dylan, I tried Google but not much luck. If you have any more information it will be gratefully accepted.
    Kind regards
    Woodgrub
    Oct 2014
    The top of mine will randomly go really dull so that it is almost unreadable. And the bottom will still be bright.
    I assume there is a bad solder joint somewhere?
    Aug 2006
    Papua New Guinea
    I had to get the instrument cluster on the beetle repaired recently. Took it to this guy Attila Instruments Calibration and Instrument Repair Service Home Page who was good. My problem was with the stepper motors, the beetle doesn't have an MFD, so it's not the same problem but it might be worth giving Attila a ring to see if he can help. He seemed to have a bit of everything in his workshop!
    Greg
    2002 New Beetle Turbo
    Jul 2007
    Brissy
    Quote Originally Posted by drucejnr View Post
    More details please !
    Both my Mk5s have this issue, some days its crap then others it is fine.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
