The pressure should be 30psi (2BAR).
If you using the type of bleeder that just pumps the air into the container with the b.fluid and the air comes in contact with the b.fluid, then you're introducing the moisture from the air into the b.fluid and also the micro bubbles. Certainly not the correct way to bleed the brakes/change the fluid.
