Results 21 to 30 of 31
Thread: MKIV GTI has developed a miss
  1. #21
    Apr 2008
    Yeah must be a DV. Aren't they virtually the same thing?
    I might try disconnect the MAF and see what happens...
    2000 Mk IV GTI
  2. #22
    Apr 2008
    I unplugged the MAF but it didn't seem to make a difference. It's running rich because I can smell petrol but I don't know if it's related to the MAF being disconnected..
    2000 Mk IV GTI
  3. #23
    You can disconnect the MAF but that's not always going to prove the MAF to be faulty. My mates A4 with APU motor, seemed to run OK somedays and not others. Disconnecting the MAF made no perceptible difference. It wasn't 'til I chipped it for him that we could see for sure that it was dieing. It was only failing big time when under boost.
    We had previously logged the airflow and even that looked to be good.
    If you can get back on the VAG-COM and do a couple of runs in 3rd gear from 2000 revs to the redline while logging the airflow, that would be a good test of the MAF.
    There is a formula on ross-techs site that tells you how to convert Airflow to hp. I reckon it could be divide by .8. ie for a std AGU you would get around 120g/s.
    On the Audi you could see the airflow drop to zero intermittently while under boost, completely giving the game away.
    If you could borrow a MAF from another good car, I'd try that over disconnecting.
  4. #24
    Jun 2007
    Dirty West!
    I had a similar issue with my mk4, found out it eventually that it was the MAF...it seemed that the old one didnt exactly die...but didnt exactly work...if that remotely makes sense.
    But the symptoms you describe are very much similar to what i had.
  5. #25
    Apr 2008
    Quick update. I was lucky enough to have use of the VAG-COM again and logged some data this time (thanks Marshall). Of course tonight when I drove the Golf it barely missed a beat; it actually ran better than it has for a while.
    First up VAG-COM showed us an error specifically with the MAF different to the faults I posted up earlier. Also bear in mind that the codes were cleared after scanning the first time. I forgot what the fault was exactly but it had something to do with a signal from the MAF that was too low/intermittent.
    Below is a back-to-back comparison of my Golf (the blue table) and a normal running MKIV GTI. The blue table was not done under load (i.e. just blipped the throttle a few times whilst stationary) whilst the red table had some WOT action.
    Okay so we've concluded the MAF on mine is buggered and getting false/bad readings for some reason, but we're not mechanics . Could it be as simple as dirty sensors in the MAF? I was considering giving it a squirt with carby cleaner or something.
    Car will be serviced in the coming week.
    2000 Mk IV GTI
  6. #26
    Assuming both runs were done with full throttle, there is something amiss with yours.
    To do a decent log you need to have it pull up a hill in 3rd (4th is better but you'd be locked up most likely) from 2000 revs to the redline is possible. The steeper the hill the better, the engine won't accelerate so quick and you get decent info in the logs cos the parameters aren't changing at lightspeed.
    What about swapping MAFs with Marshall and doing a run? Depends how much you can get a replacement for.
    Jmac has one that belongs to me, it's brand new. Let me have the part number. You can try it for the cost of postage.
  7. #27
    Apr 2008
    Geeze mate you don't muck around Love it!
    We didn't end up swapping MAFs because my car was behaving as normal and I didn't want to take up his whole evening.
    Gavin that's a fantastic offer!! How much do they retail for? MJM Autohaus and German Auto Parts sell them for about US$180. I will get you a part number and PM you.
    I must say you Dubbers are a seriously friendly and helpful bunch! Thanks so much for the help and the new found knowledge along the way
    2000 Mk IV GTI
  8. #28
    I know how much of an arse it is, doing the running around to find bits. You would be surprised that Imparts were with a handful of dollars more than I paid to get this one over from the UK.
    037 906 461 C is the part number for the one I got.
    Oh and if I am nice to you, you might have your car chipped....
  9. #29
    Aug 2007
    Five Dock, Sydney
    I also have a spare MAF, brand spanker Bosch, but its sitting in my car boot, and I am cozy inside so I'll post the part no tomorrow.
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
  10. #30
    Apr 2008
    Hey chaps. Just a quick update.
    The car was running fine for a while but would still occassionally feel like it's missing/loss of power/idle like a truck. I finally found time (well, I found someone else with the time!) to take my car to VolksPower to get a new MAF. Dean was a bit funny about replacing the MAF saying it could be anything even though their report brought up a MAF error. Well he replaced it anyway and the car is running like a champ
    It cost approx. $250 for the MAF and $40 for labour. A bit exxy so I just hope it doesn't eff up any time soon. Will be interesting to see the VagCom diagnostics now...
    2000 Mk IV GTI
