Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: MKIV Cluster Mods (Software Based)
  1. #61
    Apr 2008
    Quote Originally Posted by Fizz View Post
    if your golf doesn't have an MFA like mine then't you have the same issues that I'm having, but if your car has an MFA then it'll be fine
    There are rumours that if you get the full MFA rather than Half MFA it is compatible with the early Mk4's without MFA.
    Nope - no MFA hence why I want the upgrade.
    2000 Mk IV GTI
  2. #62
    Nov 2006
    Brisbane Qld
    The only really tricky bit is the airbag warning light is activated thru canbus on later cluster.
    If you want a fully functioning FIS with the proper car emblem showing which door is open then you also need to swap over the CCM and window motors to the later ones as well.
    If you get a Passat cluster you need to swap over the faceplate to the Golf version as they are a different shape.The later Passat with the chrome rings works too but you still need the Golf faceplate but the gauges will look funny as you will see the outline of the round Passat gauges printed on the foil thru the golfs gauge cutout section.
  3. #63
    Aug 2007
    Perth WA
    My cruise control light has never lit up; can this be corrected with VAGCOM or is one of these hex cracks required?
    I'll add that to the wish list of DTE haha
    MY03 GTI.
    '04 BMP MkIV R32 #144
    search getnew
  4. #64
    Nov 2006
    Brisbane Qld
    The light function is controlled by an engine ECU signal via canbus.
    The function is programmed into the engine ECU chip.
    Its not hardwired directly from the cruise control switch or anything like that.
    Maybe the LED itself has blown in the cluster.
    If not, then its not in the chip program.
  5. #65
    Aug 2007
    Perth WA
    Righto, my guess is it's program related as I'm sure I've read other posts where people have said their light never came on either. Might vary from MY to MY and the different clusters.
    search getnew
  6. #66
    Jun 2008
    Sydney, The Hills
    yer mine never comes on either, always thought that was strange since you can see the logo for it, but no light. always just thought the bulb was gone, maybe its not after all...
  7. #67
    Jul 2007
    Brissy
    If its of any interest...
    Cruise light does not come on in my GTI, never has.
    I don't have the multifunction display thing either.
  8. #68
    Jun 2008
    Sydney, The Hills
    Quote Originally Posted by JustCruisn View Post
    Mustn't be a bulb problem then...
