Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 68
Thread: MKIV Cluster Mods (Software Based)
  1. #31
    Feb 2008
    New Zealand
    Quote Originally Posted by chris. View Post
    where can you get those clusters from ive been looking around and cant find them??
    if you want one i know of one available here in NZ that is used for 200 NZD i can get it and post it to you if you like
    its a MKIV GTI cluster that goes to 260kmh but has the fullsized centre (you need a few wires plugged in to make your radio station display on the display (this will only work with a VW Radio
    but you will need VAG tacho and Vag Com to introduce it to your car..
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
  2. #32
    Jun 2007
    Toorak, VIC
    Quote Originally Posted by HitmanR32 View Post
    Distance to empty is only available on Immobiliser3 clusters
    ie
    Glidns car had an imobiliser 2 cluster
    1J0 902 821 A
    so i got him a immobiliser 3 cluster which was
    1J0 902 826 A
    If the number in red is a 2 it means it has a half height display if the number in red is a 4 it means its is a full height display if it is a 0? or a 1 i think its no display
    and the number 6 at the end means its immo3 if it was 1 or 5 it is immo2
    make sense?
    anyway to tell which cluster model you have without removing it? its an 03 GTI
  3. #33
    Feb 2008
    New Zealand
    03 its more than definatly a Immobiliser 3 car
    you can always plug in vag com and log in to channel 17 - Instruments it should have the part master there
    oh also it must be a VDO Cluster not Motometer
    - 2010 Golf R
    - 1997 Golf VR6
  4. #34
    Aug 2007
    Five Dock, Sydney
    I believe I have an Immob3 cluster going by my VAGCOM scan...
    Address 17: Instruments
    Controller: 1J5 920 826 A
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 07724
    Shop #: WSC 00000
    WVWZZZ1JZ3D016500 VWZ7Z0B6138908
    No fault code found.
    Can I use Adaption codes to set the Distance-to-Empty feature?
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
  5. #35
    Jun 2007
    Toorak, VIC
    sweet cheers
  6. #36
    Jun 2008
    Sunshine Coast, Queensland Australia
    Quote Originally Posted by ope126 View Post
    I will be ordering one over the weekend.
    Hopefully it doesn't take too long to come from the UK.
    Glenn
    ever end up getting it mate??
  7. #37
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by patullose View Post
    Yes he did. I believe he gave it to Jimmy Mac in return for a nice discount on labour or parts for his car. Jimmy now offers the service as part of his business.
    See link here: http://www.vwwatercooled.org.au/newf...ad.php?t=15898
    Hope you don't mind me responding to this Glenn or the free advertising Jimmy.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
  8. #38
    Jun 2008
    not at all mate...cheers
  9. #39
    May 2007
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    Another plug for JMAC!
  10. #40
    Oct 2006
    i think a lot of the gti's are motometer dashes where the r32s are usually vdo! argh!
