if you want one i know of one available here in NZ that is used for 200 NZD i can get it and post it to you if you like
its a MKIV GTI cluster that goes to 260kmh but has the fullsized centre (you need a few wires plugged in to make your radio station display on the display (this will only work with a VW Radio
but you will need VAG tacho and Vag Com to introduce it to your car..
