they're supplier is a friend of mine lol.
if you guys want to do a group buy let me know and ill see what i can do as im sure i can do much better then he can in AUD![]()
count me in
Any further info on this?
Wouldnt mind switching on the DTE if possible.![]()
MkIV GTi
Can someone tell me what MKIVs did and didn't come with the small red section at the bottom of the cluster? [The part with petrol/ambient temp etc] Mine's a 2000 GTI and doesn't have it - it'd be nice if it was just a dead globe but I don't have the buttons on the end of my wiper stalk to scroll through the options![]()
holey crap this is funny sorry
but Glidns old alias was Dubbed
and im reading your message going wtf are you on about dude.. i fitted in a Immo3 MFA in the weekend and enabled distance to empty and **** like that!
sorry lol
you can upgrade your car easy as
just need to do a little bit of wiring there are guides to it on the tex
http://forums.vwvortex.com/zerothread?id=1921113
just get the VAG TACHO software and get a second hand immo3 cluster
(they are way better more feature ritch but are a little harder to get working initially!)
Distance to empty is only available on Immobiliser3 clusters
ie
Glidns car had an imobiliser 2 cluster
1J0 902 821 A
so i got him a immobiliser 3 cluster which was
1J0 902 826 A
If the number in red is a 2 it means it has a half height display if the number in red is a 4 it means its is a full height display if it is a 0? or a 1 i think its no display
and the number 6 at the end means its immo3 if it was 1 or 5 it is immo2
make sense?
you need vag tacho to do the EEProm dump from the cluster
then you go to address $416 and replace the byte "C1" to "E1" save it and then re flash it
you can also do the needle light up mods etc
now i have changed mine so that the needles are always lit and then the cluster lights right up when the headlights are on![]()
