Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: MKIV Bora Cruise control & Gear Changing
    Jun 2008
    Broadmeadow, Melbourne
    Since i got my head unit installed yesterday it seems that the cruise control has shat itself completely, could this be linked to the head unit install, maybe the guy ****ed up some kind of electrics? not sure
    another thing is when ever i seem to change up gears especially from 2nd to 3rd i get this jolt forward, never happened before. I'm a newb so the only thing i could bloody put it down to is that some kind of fuse is blown or the ECU is effected, im so pissed off because i used the CC to get to this place and the moment i drove out, car felt different and CC was buggered.
    Any help/advice is appreciated guys
    Cheers!
    Apr 2008
    Maybe it's just a blown fuse, but if it's not I'd be taking it straight back and demanding some answers.
    2000 Mk IV GTI
    Jun 2008
    Ringwood, Victoria
    X2.
    Probably did the old chop chop of wires than held them all together with those hideous screw butt connectors the duct taped it all together!
    Jun 2008
    saw the guy doing most of it, seems really well done. Ive taken it to Volks Affair so they can see if anything is up
    just really not sure whats causing the huge jolts forward when upshifting. could it be ECU related? if so could i just reset it?
    Feb 2008
    Auckland NZ
    ok the chances are the install of the new radio did not cause the problem/s you are experiencing, but in saying that, if the K-line has been connected to your new aftermarket radio then it will start throwing error codes inthe ECU, which in turn could potentially cause it hence i'm mentioning this to you.
    out of 7 golf/bora/Jetta Mk4 radio's i have installed only one of them have i actually used the factory radio harness.
    Hopefully this sheds some light that you can try and pin point on.
    Also do you know anyone that has vag-com that can scan your car for you?
    Maybe then you can find out what the problem is.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Jun 2008
    Quote Originally Posted by glidn View Post
    yeah it was the afternmarket headunit interfering with the CC and ECU
    volks affair just called me up and charged me $297 for the ECU reset and the CC reconfig.
    FFS!
    and this was caused by the ****in car install place
    May 2007
    Moonee Ponds
    hmmm i used teh factory harness with some aerpro adapters. Seems to be working ok for the past year and a bit. But yah, one minutes its working the next it isn't, something they have done. But maybe the problem was always there just lurking until they touched something to make it more obvious.
    Jun 2008
    Quote Originally Posted by qsilverza View Post
    nah it wasnt though, the CC would work consistently and the bunnyhopping was non existant!
    im so pissed mate, and this isntall place was recommended by volks affair
    Apr 2008
    lol what the ****! That's a scam and a half. I would not be paying that 300 odd pingers!!
    2000 Mk IV GTI
    Jun 2008
    tell me about it! im fuming!!!
