Results 1 to 10 of 15
Thread: MK4 wheels - will they fit
    Mar 2007
    sydney
    i know the description says they will fit an mk4 just wanted some confirmation. will be going with either one...decisions decisions
    http://cgi.ebay.com.au/1999-Volkswag...item255a3db7c5
    http://cgi.ebay.com.au/VW-GOLF-MK4-B...item20b081c829
    2004 GTI, GIAC, DOWNPIPE
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
    Links arnt working for me for some reason...
    But why going back to 15s?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2007
    sydney
    i will fix links tonight.
    Sydney roads are crap or my car is just too low. so hopefully the bigger profile tyres will help. have had the wheels on the car for 4 years so want a bit of change...maybe some power gain going down to 15's
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
    Mar 2007
    sydney
    why not 16's? though the second lot look ok
    and you sure you're not down on power for other reasons? tune and downpipe should give you enough juice, so perhaps you've got boost leak or something like that. or you're just used to the power i guess. i can't imagine big wheels slow you down tooooo much. but from 19 to 15 is a BIG jump! I'd go 16s min
    not sure why the links arn't working, i tried too, but search item number 160427784133 for first one and 140400248873 for second one in ebay http://www.ebay.com.au/
    Jul 2007
    Brissy
    Oh I can't get the links to work either.
    They should fit 5x100 is the correct bolt pattern
    I'd go the 16s, they look better.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    I think eBay did something funny about their URL, can't cut/paste them into here
    Dec 2006
    Kilsyth, VIC
    I have fixed the links in the first post. It's a little odd, it seems if you post a link from a search for an ID number it doesn't work, but if you post a link from an item directly it does... I'm looking into it.
    the stock wheels on gti are 16, so i'd double check the front wheels clear the brakes?
    Mar 2007
    sydney
    ye i agree the 16's look better. i wouldnt mind the 15's because then the actual body of the car will sit lower to the ground.
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
