Results 1 to 10 of 11
Thread: MK4 Version: off center rear axle fix*
    Apr 2011
    Berwick, Victoria
    Lightbulb MK4 Version: off center rear axle fix*
    Off center rear axle fix*
    *There is not much adjustment at all but keep in mind if you're poking 6mm more on one side, you need to half it for the center!
    Just like KI11Z posted for mk3 here
    I happened to do this on the weekend as well. It was required for me to go lower because of my wheel offset and limited tyre stretch (1 size under, 215/40/r18 on 18x8 )
    You first want to calculate how far you need to shift the beam while the car is on the ground!
    I knew that my right wheel was poking around 5mm more then my left wheel, so my calculation was
    5mm more 'poke' on one side, center is 5/2=2.5
    So I needed to move the beam around 2.5mm to make it look normal.
    Here's a picture of your rear beam, the red dots indicate the 8 bolts you will need to loosen to move the beam over.
    More reference pictures:
    VAGdrivers - sponsored by Alloy-Wheels.ie > Mk4 Rear Axle Bushes
    Obviously you want to jack your car up and place it on stands at the back and make sure everything is secure before crawling under the car. You'll also want to take your rear wheels off
    Once I loosened one side, the bracket and beam actually pushed forward towards the front of the car*
    You want to grab a rubber mallet and wack the side thats poking more, it won't take much to move it over, you SHOULD be able to clearly see the washer marks on the bracket, I used these marks as a guide for correction. (The MK3 version has some pictures with these marks on the bracket for reference)
    *Now, if your bracket did happen to push forwards like mine did {it was only around 2mm but still} (you will again be able to tell by looking at the washer marks on the bracket). You want to correct this, otherwise your beam could be
    a) lob sided
    b) pushed forward towards the inner guard more, which if your golf/bora is low, you certainly don't want this!
    What I done was push the beam across first, THEN I nipped the bolts up to be just enough to grip
    After I nipped the bolts up, I hit the bracket that pushed forward with my mallet and placed it back to it's original vertical? placement.
    I just tightened them fairly tight, my bolts were fairly easy to take off, not a great force required.
    I ended up pushing mine across this far, there's no ruler but it's average texta size.
    I placed a piece of pine flat on my hub and marked it on the ground, but remember the washer marks on the bracket is your best measurement! The picture should actually be flipped 180 degrees but you will get the idea as this was my left side.
    everyone is correcting the rear beams!
    Nice work. Will have to do mine shortly
    Aug 2007
    Perth, Australia
    does this apply to FWD mk4s only or are AWDs affected too?
    1991 BMW 318is RED E30
    Quote Originally Posted by balkanac View Post
    i think AWD can be affected too. but id imagine your method of moving everything would be a lot different
    Mar 2010
    Lesmurdie
    I don't think so? Its due to the rear beam and the AWD has in depended rear suspension AFAIK
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    nice! May need to do this on the Lopo soon
    Quote Originally Posted by Back Door Shenanigans. View Post
    yeah but you have a subframe at teh back yeah? I believe that can be off centre...
    Sep 2006
    West Sydney
    Top post Matt!
    Feb 2010
    Launceston, tas
    This is tops! I have to have a go at this! Although I think my left side might be just cambered more than the right or something ehhhh
    Quote Originally Posted by undisclos3d View Post
    thats not good on a solid beam car...
