Results 1 to 6 of 6
Thread: Mk4 upgraded strut mounts
    Jan 2011
    Gold Coast, QLD
    Hey people,
    Has anyone upgraded their rubber strut mounts?
    2 options i have found have been..
    1)solid strut mounts? Surely this is a track only option?
    VW GOLF MK4 FIXED 2 PIECE TOP MOUNT KIT PAIR - Parts by Car Manufacturer - VW - Golf MK4 - VW GOLF MK4 FIXED TOP MOUNTS (PAIR) - Compbrake - Designers In Motorsport - (Powered by CubeCart)
    2) SEAT cupra R strut mounts
    VWVortex.com - OEM Heavy Duty Strut Top Mounts - YES - there is one available!!
    Any opinions?
    ---------- Post added at 08:54 PM ---------- Previous post was at 07:24 PM ----------
    Reference: VWVortex.com - How to replace front strut mount rubber without a spring compressor.....long
    Sep 2006
    Do you want some camber or not
    MODS- TOO MANY
    Jan 2011
    Gold Coast, QLD
    Just stock camber
    ---------- Post added at 09:56 PM ---------- Previous post was at 09:33 PM ----------
    Also how do I torque the top strut nut correctly????
    I need to hold the centre bit with the allan key... but then the torque wrench doesnt go over..
    otherwise it just spins around without holding the centre bit
    I ran R32/TT ones with my coilovers, made a big difference
    you have the right idea with tightening them, just need to find a socket that you can get a spanner or something on to
    Sep 2006
    West Sydney
    I'm running 034motorsports street density mounts at the moment. I went for the Audi 90 versions as they allow the car to sit lower, but they also have Mk4 versions too.
    Sent from my iPhone using Tapatalk.
    Jan 2011
    Gold Coast, QLD
    Ok cool thanks guys, the 034motorsport ones are good, but the shipping is intenso..
    Ill see if i have some friends in the UK or someone locally who can source me the SEAT cupra leon R strut mounts..
    Also found a solution to the tightening issue...
    - torque wrench
    - sparkplug socket
    - vw special tool 10001/8 or something similar...
    ---------- Post added at 09:47 AM ---------- Previous post was at 09:28 AM ----------
    Also found this fancy tool for holding strut bolts.
    Part MN2122 - Specialty Double 21 & 22 mm Strut Nut Sockets
    Specialty Bits and Drivers - VW Engine Tools from Metalnerd
    ---------- Post added at 10:12 PM ---------- Previous post was at 09:47 AM ----------
    I cant order the vw special tool....
    Does anyone have any ideas what i could use instead?
    will something like this work?
    14 Pc Extra Long Hex Bit Sockets Allen Wrench MM+SAE | eBay
    The thing is i only need the one.....!
    gah
    ---------- Post added 28-01-2012 at 05:52 PM ---------- Previous post was 27-01-2012 at 10:12 PM ----------
    Quote Originally Posted by rayray086 View Post
    I'm running 034motorsports street density mounts at the moment. I went for the Audi 90 versions as they allow the car to sit lower, but they also have Mk4 versions too..
    Hye rayray, where are the street density mounts you are talking about ? What durometer rubber are they?
    I can only see the track spec... Strut Mount, Track Density, Mk 4 Chassis VW and Audi - 034 MOTORSPORT
