Results 1 to 4 of 4
Thread: Mk4 reversing lights not working
    Oct 2013
    Buderim Qld
    Hi All, I am hoping someone might be able to help with my latest problem, the reversing lights have stopped working, I have checked both bulbs, they are ok,I have checked wiring which I think comes from switch on top of gearbox, can't see anything wrong, I have checked most fuses but am unsure which fuse is the correct one. If anyone can advise my next step I will be very grateful.
    Kind regards
    Woodgrub
    May 2014
    Canberra
    I am having the same problem with my Mk2 5 speed box in my golf - from what I have read and seen on mine - the contacts get burnt out! I have a new switch ordered and will be fitting a relay to take the load away from the reverse switch and hopefully stopping the switch burning out.
    Mar 2013
    Brisbane QLD
    on your mk4 take the plug off the reverse light switch on the gearbox. should have 2 pins. bridge the 2 pins together with a piece of wire or hair clip etc. with pins bridged and ignition on if they work then switch will be faulty.....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Oct 2013
    Buderim Qld
    Thanks for the help guys. I will bridge it out as soon as I can.
    Regards
    Woodgrub
