Results 1 to 7 of 7
Thread: Mk4 rear guards?
    Jan 2014
    Adelaide, East Side
    Mk4 rear guards?
    Hi guys, some of you may know I've purchased a new GTI and I'm currently after some help.
    Is it possible to pull the rear guards a bit with a guard roller and heat gun to stop it from munching away at my tires haha?
    Also what're your opinions on adjustable sway bar connections for the front to drop it a bit lower?
    Some pictures for reference in regards to rubbing
    __________________________________________________ ______
    MK4 GTI - Reflex Silver - <<<Click for Build!<<<
    -Previously Owned a MK4 1.6L Golf - Reflex Silver
    The biggest drama you face running that low is the wheel swinging forward in the arch. There's plates out there (ECS) to move the axle back so the wheel is in the middle of the arch again.
    I appreciate the pursuit of looks but don't forget you are compromising handling at the same time.
    bro so dope.
    leave the rear arches. they can tuck 10s easy. molested mk4 arches look horrid
    as for the front. just remove the sway bar. its not going to handle once you lowered it so might as well chase some comfort
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by caputo9 View Post
    Are you still running the stock sway bar or is it upgraded? The upgraded aftermarket sway bars are usually made with lowering in mind and don't tend to rub. Getting them in without a hoist is an exercise in frustration, but possible ...
    I'd respectfully disagree about taking out the sway bar completely unless you only drive on straight roads - it's not like the Mk4 is the sharpest handling car on the block to begin with and having no sway bar is going to make handling a whole lot worse.
    I guess it depends what direction you're going with this build - looks or handling?
    Jan 2014
    Adelaide, East Side
    Thanks guys!
    After some effort today I pulled the liners out and took a little lip off the edge of the guards but it's still rubbing on the inside
    With some thought and my parents encouraging me it's being raised up to a more reasonable height tomorrow
    Continuous rubbing over tiny bumps has gotten to me and I have noticed the difference in handling aha
    Swaybar is staying put and I'm yet to have any issues with it rubbing so I think it should be fine even at the current height
    I've had my fun but this height really isn't practical and getting a defect is the last thing I want Mk4 rear guards?
