Results 11 to 20 of 21
Thread: MK4 radio wiring diagram??
    Munno Para West Adelaide
    good news! The harness I had fitted the factory plugs and all seems to be working fine!
    Aug 2012
    Did you take a photo?
    I've got a Pioneer DEH 80-PRS install coming up in a few weeks.
    Quote Originally Posted by dubster99 View Post
    which one was that?
    actually not yet, I will though once it gets back from the mechanics!
    Quote Originally Posted by remy View Post
    It was the old harness i had from when i had the head unit in the falcon. when 'djorkboy' mentioned about the eurovox adapter I took a look and saw that the plugs looked the same as the adapter I had and were the same colours so I plugged and HEY! it worked fine! I used the stock sleeve for the head unit as the pioneer one moved around too much and all sits in snug now!
    which one was that?
    im doing the same in the GFs polo, will have to see whats down there behind the dash then
    Hey guys so ive had no time to fix this problem yet but thought I would ask you guys. When ever I turn my ignition off and on the headunit doesnt resume the setting it was on 'cd player' it goes back to standby? :/
    Also the ariel adapter has a blue wire attached to it so I connected it to the blue ariel wire but my reception is still shocking. And advice guys?
    Pacific Paradise QLD
    The adapter wire would be to provide 12v to a powered aerial wouldnt it
    Wont make any difference to reception.
    The reception comes from the big thick wire with a banana type plug which goes into a socket in the back of the unit.
    It sounds like you have the power from battery and accessory memory (always on ) reversed.
    You will find out if and when battery goes flat.
    Have done this myself once,
    I wouldnt have a clue which is the memory wire. My battery hasnt sounded like its going to fail but i'll check voltage. The ariel adapter plugs into the headunit and into the existing ariel cable behind dash. The blue wire that trails off adapter has me stumped :/
    Read this Google Image Result for http://home.comcast.net/~derek-kelly/element/audio/eaudint.jpg
    Or this http://answers.yahoo.com/question/in...4151221AA1HBWe
