Do some research on the 8L Audi S3 space saver. Some pop up every so often or you can buy a set directly from an Audi dealer (at a premium of course). The full kit includes a jack that works and you can normally specify a stainless or alloy unit it's not a perfect setup, the jack is regarded as useless at best or dangerous at worst. Also the space saver doesn't fit over the front brakes so if you get a flat on the front you need to put the space saver on the rear and move a good wheel to the front. The set also fits perfectly in the boot without taking up any space.
Cheers,
Trent
