Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Mk4 R32 quick questions
    Nov 2006
    Brisbane Qld
    Mac883 - make sure you get the factory plugs and bit of harness as well, so you can resplice it back on the end of your harness.
    Thanks for the comments Trent.
    Aug 2009
    Campbelltown, NSW
    my harness is actually in tact... The loom that I provided shots of has been added on... even had the right connector.
    Graeme86, are you certain all the mk4's all use the same bulb holder? I have seen triangle shaped ones as well...
    Does anybody know of a big VW wrecker in Sydney at all? Thought Pick n Payless may have some golfs but when I rang they said they didn't
    Nov 2006
    Brisbane Qld
    All Mk IV's here have the same bulbholders.
    The "triangular" ones you have seen might be Mk 3 versions.
    Aug 2009
    Campbelltown, NSW
    If you look at the pic that Graeme86 supplied, the plugs on the loom for the Altezza style lights I have, look as though they plug into the bulb holder...
    Not sure if they are any different in the other countries but instead of having the one plug into the back of the bulb holder, it looked as though you could have individual ones...
    I have the new bulb holders which I picked up from Parramatta Prestige over the weekend. Will try and fit the lights tonight
    Nov 2006
    Brisbane Qld
    Those individual plugs on the back are for taking wire taps off the rear lights when you install a trailer loom (then you dont have to hack up the factory loom).
    You can also put a test light on them etc.
    ....also handy for the 5-brakelight mod.
    Aug 2009
    Campbelltown, NSW
    Ah I see! So what is this so called 5 brake light mod you speak of!?
    Oct 2006
    Quote Originally Posted by graeme86 View Post
    the 5 brake light mod is very very bright, looks terrible and is blinding when your behind the car.
    Aug 2009
    Campbelltown, NSW
    lights are in... does the passenger fog light work on all R32's? I seem to be missing a wire... Harness does not appear to have been touched
    Nov 2006
    Brisbane Qld
    There is only a foglight on the drivers side.
