No it doesn't it's a do it yourself mod, well for MKIV R anyway.
Take the grill out using a small flat blade screw driver to carefully lift the bottom tabs, get a decent quality narrow box cutter or scalpel (hobby shops have these), some extra blades and a hair dryer.
Gently heat the grill for a few seconds with it facing up on a solid surface and push the blade through following each edge of the diamond. Once all of them are out fold up a piece of wet n dry and gently smooth out the dags. Make sure you leave one row solid around the outside edge as per the one already open on the other side of the car to keep it rigid enough so it doesn't pop out. Takes about 30 minutes to remove all of them and sand the dags off.
Cheers Al
