Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Mk4 R32 Perforated Grills
    Dec 2007
    Auckland, New Zealand
    Hey Guys does the Ozzy R32 have both the left and right Lower Front Grills perforated? As Ours only has one side perforated and my mate with the R wants to have them both. If the Ozzy R does come with the perforated Grills anyone has a part number?
    Thanks
    Jan 2007
    Quote Originally Posted by Fizz View Post
    Thanks
    No it doesn't it's a do it yourself mod, well for MKIV R anyway.
    Take the grill out using a small flat blade screw driver to carefully lift the bottom tabs, get a decent quality narrow box cutter or scalpel (hobby shops have these), some extra blades and a hair dryer.
    Gently heat the grill for a few seconds with it facing up on a solid surface and push the blade through following each edge of the diamond. Once all of them are out fold up a piece of wet n dry and gently smooth out the dags. Make sure you leave one row solid around the outside edge as per the one already open on the other side of the car to keep it rigid enough so it doesn't pop out. Takes about 30 minutes to remove all of them and sand the dags off.
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Aug 2007
    Perth, Australia
    i have a CAI air filter behind it, i dont think i'll be opening it
    1991 BMW 318is RED E30
    Dec 2007
    Cool, we'll give it a go this coming weekend
    Thanks Al
    Jan 2007
    Quote Originally Posted by balkanac View Post
    That was the nice thing about using the BMC CDA intake the hose hung down there but there was no issue about the filter getting wet or it sucking in water.
    My Garage
    Aug 2007
    Perth, Australia
    thats true quozl, but when i was deciding which CAI to get, BMC one was way too expensive, so i went with Neuspeed and i love it!
    Dec 2007
    Brisbane, Southside...
    Hmmm.... Thoughts for future modification plan.
    I take it the BMC Air Filter is the best CAI option?
    How then does the Carbonio compare to the Neuspeed?
    Al, how come with the BMC intake you don't have to worry about water entering? Looking at the BMC site they say not to put the intake down too low.
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jan 2007
    Quote Originally Posted by Treza360 View Post
    Trent
    Any intake will suck water if you drive through deep enough water. As you can see by the pic above the intake hose was only slightly turned down where a lot of the pod type filters sit right down behind the horn making it easier for water to be ingested.
    When I was running the BMC I never had an issue in any of the rallies I competed iat with ingesting water and some of them were very wet. With the updated CAMS Tarmac rules I am no longer allowed to run an intake it has to be stock so we run the DSG R32 MKIV airbox and intake from the Euro R as it is a larger intake pipe than the Australian version. Testing with VAGCOM showed it was pulling the same gram per sec air as the BMC.
    As for which intake is better I'm not touching that with a 10 foot pole, when i installed the BMC in early 2004 I went with it as it was the only option available at that time.
    Just after this picture was taken at Wheels on Wide Bay I went through the main part of that puddle and water was everywhere over the bonnet and screen but had no ingestion issues, your only going to have a problem with any intake if the road is flooded and your trying to ford your way through, in saying that though if the pod filter is down there it's going to get wet and stay wet allowing some water to be ingested where as with the hose in the position I had it there's nothing there to trap the water.
    Cheers Al
    My Garage
    Dec 2007
    Quote Originally Posted by quozl View Post
    <snip>
    Thanks Al. Lots of food for thought. A CAI will be a few months away anyway. Tyres are first on the list.
    Aug 2007
    Perth, Australia
    If you are so worried about sucking up water, get a bypass filter and nmount it inder the bonnet and you'll be fine
