Results 1 to 10 of 13
Thread: Mk4 .:R32 Clutches
    Jan 2008
    Newcastle, NSW
    Mk4 .:R32 Clutches
    Hi all,
    Mine has decided to start slipping so I'm up for a new clutch, have read info elsewhere but curious to see how the aussie guys went about replacing theirs.
    Have got a quote from the local stealer for supply of clutch plate, flywheel, breather and bolts, you don't want to know the $$$.
    Am scouring aftermarket/online stores, but as I said, keen to here from guys here to see what they went with??
    TIA
    Mal
    Jun 2009
    I believe DXD supply heavier duty clutch/flywheel.
    APR uses them apparently.
    Check out their website:
    South Bend Clutch - DXD High Performance Clutches
    Then go to catalog and select VW on the left.
    Aug 2007
    Perth, Australia
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by team_v View Post
    Ta, had a look but found "website is under construction".
    Jan 2008
    Newcastle, NSW
    thanks mate, haven't caught your name around before?
    Yesh, had shortlisted Spec Stage 2+ inc LW aluminium flywheel or the ECS Stage 3 with LWFW. Both between 1200 and 1300USD + shipping.
    Aug 2007
    Perth, Australia
    the name is nik. I've been on this forum since '07
    1991 BMW 318is RED E30
    Jan 2008
    Newcastle, NSW
    Thanks Nik, been on since early 08
    Mar 2009
    Isn't there a different clutch in the car now anyway Mal?? Why not find out from old owner (can't remember his name) about where he sourced his from....
    Jan 2008
    Newcastle, NSW
    Quote Originally Posted by 2000MN View Post
    Is apparently a Sachs one in it at the moment Corey.
    Gave Paul a call last night with no answer.
    Have the Mike Webber sticker still on the car, will give him a call on Monday and see what I can find out.
    At present the Spec items look like the winner though...
    Thanks champion!
    Townsvegas QLD
    It depends on how you drive your car and what mods you have and if you plan to add some performance upgrades at a later time. Depending on what you want to spend you could get the factory FW resurfaced and just get a clutch, pressureplate, TO bearing and slave cylinder. I think it easier to add fluid to the new slave cylinder/TO assembly before you install it--makes bleeding the clutch easier. I'm running a Spec Stage 3+ with singlemass flywheel I didn't go to light as I didnt want to loose TQ. But I do get a little bit of chatter with the singlemass FW with the clutch pedal out. A mate hooked me up for cheap thats why I got it and its been good so far.. Clutch master, south bend and Streetwerke all make nice clutchs. I think when I get back home and the clutch is done I'm going to switch to a DM clutch as I want to make around the 600-650Awhp.
    DM Motorsport - clutch
    Clutch Masters- Your High Performance Specialists
    Hope this helps J
    SLAM.POKE.TUCK.DROP.DOPE!
