Results 1 to 10 of 12
Thread: Mk4 Overheating & Thermostat Working..
    Aug 2009
    Exclamation Mk4 Overheating & Thermostat Working..
    The Mk4 GTi has developed an overheating issue.
    Last Friday AM, I drive 4kms which was enough for the engine to warm up and continue past its normal temp (90deg) to 120deg. The temp. alarm come up so I parked at work and turned the car off. It was a little dark under the bonnet to inspect but nothing seemed out of order. As expected the thermo fans started up to cool the poor thing down.
    Friday PM, drove 5kms home, did not overheat... normal temps.
    Saturday PM drove 10kms, overheating issue again, pulled over had a decent look/feel to notice the top hose where the temp. sensor lives to be HOT! The bottom hose connected in front of the thermostat was COLD.
    Now, I only replaced the thermostat 2months ago, thinking it may be a stuck closed thermostat problem!
    Today I pulled the thermostat out and put it on the stove in a pot of water. To my non-delight, the thermostat fully opened before boiling point .. Normal operation!
    With the thermostat and coolant back in the car, we ran the car back up to operating temp. and more again!
    Frustrating and hoping its not the water pump impeller..... ANY IDEAS ??
    Have a day of site visits tomorrow too
    Quote Originally Posted by Pergs View Post
    You can hope it's not the pump but I am pretty sure that's what you'll find it is.
    Aug 2009
    Thanks Gav,
    How do the water pumps just fail?
    Do i expect to find broken and mashed impeller fins throughout the coolant? There wasn't any today?
    Thanks Gav,
    The impeller splits and the shaft spins in the middle of it. Had it happen to my A3 years back. They don't crack and fall apart in my experience.
    thermo stats normally open when they break, safety thing.
    How many km on the car, and has the pump ever been replaced? usually in line with timing belts
    Aug 2009
    149,900km on the car and I've been looking through receipts tonight and cant find a 'water pump' when the timing belt service was done.
    Question is, should I do a timing belt, tensioner and roller at the same time?!
    Aug 2013
    adelaide
    This could be why my GTI has suddenly started to run pretty much cold, takes an age to warm up, never hits operating temp unless im stuck in traffic, else, its always on the 3rd bar being cold!
    Due to the high price of bullets, there will be no warning shots!
    Mar 2013
    Brisbane QLD
    pull the small top hose off the coolant bottle and run the engine...if you get no or little flow then its the pump...good flow would be like turning your garden hose on.....if there is no flow then give it a rev..you might get a little come out if the pump is still just grabbing the impellar....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Aug 2009
    So I left work early today to take advantage of some sunshine... Floating impeller it is!
    After taking out half of the engine bay, the water pump impeller is just happily spinning on the shaft!
    Glad to confirm it as a replacement kit from ECS is already on the way!
    Aug 2009
