Results 1 to 8 of 8
Thread: MK4 Headlight Question...
    Just a quick (possibly stupid) question regarding the MK4 headlights. There is a projector like lens under the indicator light bulb:
    I can never get these to turn on. Are these my fog lights? Is there anything even in there?
    Also pulling out the headlight switch to both settings won't illuminate any green fog light indicator on the instrument panel, it used to, but it doesn't seem to want to anymore
    It would be awesome if I could get it working and just use them as driving lights!
    Cheers.
    Jun 2008
    South Coast N.S.W.
    They are your fog lights (where fitted) if you had a light in the dash and it no longer works then I suppose the first thing to check would be your fuses. I have a 2000 model Golf GLE and the fogs are located under the indicator, mine work via the headlight switch by turning 2 clicks and then pulling out the switch one click, pulling out 2 clicks turns on the rear fog which is located in one of the reversing light sockets.
    Russ
    2005 Subaru Outback 3.0 R Premium
    Albury, NSW Australia
    Sounds like a stupid question, but is the car chipped? A friends MK4 lost a few cluster lights after getting chipped.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
    Aug 2007
    Camden, NSW
    You shouldn't need to turn the switch 2 clicks right (headlights on) to turn the fogs on, you only need to turn it one click (driving lights) then pull the switch out once for front fogs (there is no indication on the dash or switch that they are on) and pull twice for rear foglight (which will be indicated by a light on the switch).
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
    Mar 2010
    Lesmurdie
    Quote Originally Posted by TazzyVR6 View Post
    Doesn't the rear fogs show up on the cluster? Mine are that way
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2007
    Five Dock, Sydney
    Yeah, the fog light indicator lamp is on the light switch and cant be easily seen, my bora also has the Rear fog lamp indicator lamp in the cluster.
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Jul 2007
    Brissy
    It is the fog, try to turn it on by pulling the switch out 1 click, there is no dash light to show it is on.
    Check the bulb, pull it out and apply voltage direct from battery. Don't touch the glass with bare hands.
    If you need new bulbs they are H3 type.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2008
    South Coast N.S.W.
    My mistake, it's 2 turns and then one click on my GT Sport as it also has the " auto " position
    Russ
