VWVortex.com - Gates Racing belt failure....Fun times
Maybe don't read the whole thread.
Also Gav wheres that app?
MK4 GTI Revo Stage 1 / BFI Dogbone Mounts / 710N DV
IF you don't have a race engine don't waste money on a race belt.
I did my own timing belt and pump. I had soooo much trouble just getting the belt to slide onto the pulleys let alone before I pulled the tensioner pin to go tight...
I only got it because it's blue.![]()
Happened to be talking timing belt on the MK4 GTi with mechanic this morning and he was talking about changing the tensioner at the same time. The oilway/galley to the tensioner and seal around it is a weakness often overlooked and the tensioner can be a bigger issue than the belt causing failure. Showed me a 1.8 block he keeps for demonstration and the oil galley is quite small.
Just sayin![]()
Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
Weekender/Project: Classic Mini 1972Dependant #2: Mk4 2001 GTi
There's no engine oil to feed the tensioner for the belt. He is possibly taking about the cam chain tensioner in the head?
You can get aftermarket kits that get away with the hydraulic tensioner and instead replace it with a 'allen key tensioner' like mk5
gtis. Hydraulic tensioner nowadays is too much hit and miss..
