Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Mk4 GTI Throttle body doesn't know what it's doing
    Aug 2013
    Disconnected the power steering switch and it now doesn't die down to 500rpm after I floor it! Still has the %5 throttle jumpy-ness which occasionally comes into play when letting off accelerator; but I am hoping it will now adapt properly.
    If it doesn't, any other ideas as to what sensors or anything else that could be buggered, stopping the throttle body from adapting? Only ever goes jolty at %5 throttle. Never any other amount of throttle.
    It idles at a consistant (compared to when it fluctuated) 1850rpm while moving though and at 950rpm (much better idle, also not fluctuating) when not moving.
    I'm guessing every sensor on this engine is buggered or something? haha
    Aug 2013
    IAT sensor maybe?
    Aug 2007
    Na mate it will still adapt even if the IAT is disconnected. Have you tried the throttle yet?? good to hear the power steer switch helped, more trouble than they are worth
    Jmac
    Alba European
    Jan 2014
    coolant sensor? new one did wonders for my car...
    Aug 2011
    melbourne
    Quote Originally Posted by Malk234 View Post
    Cool, i get the same symptoms occasionally. Ill do this as well. Cheers JMAC !
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Aug 2013
    Just as an update, it's doing it again now.
    Drops down to 600rpm after high boost and WAY more jolty, even compared to before I took the power steering switch off.
    It has a brand new coolant sensor (first thing I tried) and it cannot adapt any throttle body. Took it to Volkwerk and had a go with a brand new throttle body - with the same results.
    Gets to about %30 open and comes up with an error on ross-tech (and yes we used the right block ). It does it with any throttle body.
    Aug 2013
    Not selling it anymore.
    Taking it to volkwerk so they can fix it for me haha
    Will update once/if the problem is found
    Aug 2013
    It was the ECU making all the problems
