i changed the oil and filter, cleaned the air filter and am looking into getting a manual now. i put castrol magnatec 10/40 in it. im not used to putting in petrol engine oils, ive always had diesels so ive only ever used penrite diesel. would 10/40 be the right weight? i could only find volkwagon spec oils? also needing to get the replacement timing belt, and maybe the steel water pump. ive read hp gains from 150 to 215 just from a chip on vortex. is that likely? sounds a little to good to be true to me?
also, how do i reset the service warning? it keeps blasting me to tell me it needs an oil change, but its been done!!!!
