Results 1 to 3 of 3
Thread: MK4 Gti Rev change
    Aug 2015
    Frankston STH, Victoria
    MK4 Gti Rev change
    Hey Guys,
    Not sure whether anyone can help me out, but, no better place than this.
    I had a boost/vac hose replaced not long ago and then had all my error codes cleared last night...was driving perfect again, but when i drove it this morning, it's gone back to revving low on idle, give to take just above 600rpm..
    can anyone suggest where to start looking? i can't seem to find a vac leak anywhere. It also goes back to normal if i turn the car off and back on again... So it's kinda intermittent.
    Thanks for your help
    Dec 2007
    Melburg East VIC
    easiest thing to try is disconnect the MAF and see if the idle goes back to normal, could be a bad MAF
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    Aug 2015
    Quote Originally Posted by schwartza3 View Post
    Thank you i will check that.
