Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: mk4 gti rear sway bar
    Aug 2009
    Hi Fellas, not sure if this is the proper forum for this but does anyone know where i can get a rear sway bar in brisbane? is it possible to fit it myself and how much roughly are they worth? and is it a worthwhile mod with stock suspension?
    cheers
    Feb 2007
    Hey mate,
    I think you can order Whitline swaybars online or at Autobarn, both are easily done. There are also a few threads about installing them somewhere, I'll have a look.
    Mk3.Mk4.Mk1
    My Mk1 Project
    Feb 2007
    That's a good write up, however all photo are disappeared
    Aug 2009
    thanks for the link madglf3
    i'll check it out and decide what i'm gonna do later!
    cheers
    Apr 2008
    Canberra
    Just google places that stock whiteline gear. When i got my bars last year it was a fair bit more to buy them direct from Whiteline
    Easy to install the rear though, need min tools and a bit of time to figure out what your doing. Once you get going its all pretty straight forward though.
    ~~~~____~~~~~~~~~_\_____
    ~~~ /_|__\__~~~~~~ / //__|__\___
    ____( )|__( ) ]_MKI ___[(' )__|___( ) ]_MKIV__
    Sep 2007
    I'd re-upload them, but for some reason, I can't attach an image?
    Only option is to provide a URL to the image.
    hmmm the rear of my car creaks when i go over driveways etc slowly, which apparantly means my bushings are probably gone...
    http://www.ecstuning.com/Volkswagen-...sion/Sway_Bar/
    so is it a 21 or a 23mm sway bar?
    and does the squeaking actually mean that it's not as stiff as it should be?
    or will this simply fix a sqeak, i.e. no performance benefit.
    if so, is it worth looking locally for a sway bar. i'm running on stock suspensin and plan on staying that way for at least a year.
    Jun 2008
    Ringwood, Victoria
    audi-tone, Hell yes it's a worthwhile mod!!!!!
    Best $279 I have spent on my golf, that was through Autobarn for the 22mm blade adjustable type. If you get one, make sure you fork out the bit extra for the adjustable one, not only will you get a greater range of driving dynamics, but it will help you to understand your car's behaviour and how you can drive in each setting to get the best out of it
    Part number for the adjustable type is BWR22Z.
    McDub, if you have a standard front wheel drive golf, unless you have fitted an aftermarket rear sway bar, then you don't need to worry about the diameter. The 2 diameters you have specified are for the front sway bar, the easiest way to find out what thickness you have is to get a vernier and measure it, my MkIV rally has a 21mm front swaybar.
    Quote Originally Posted by gavs View Post
    First you say i don't need to worry about the diameter, but that doesn't sound right... you've confused me!
    i've got a GTI, and it's the rear sway bar that needs new bushings.
    i could measure it myself, but would prefer someone to confirm what it should be.
