mk4 gti no start
Uhh classic 1.8t gave the engine bay a quick degreasing and hose let it dry for 20 mins, then move it back out in the parking lot. Finished work a few hours later and no start. Just cranks. Now the fuel pump doesn't prime when I open the door. Or when ignition is on. Pump fuse is fine. Other thing was I've got a pod instead of the airbox. I've relocated the ignition amp under the cowl away from the heat. But im thinking that probably isn't enough. Can they cause no start? As I thought when they go bad it's usually a rough idle etc. Going to have a good look tomorrow for more info as I needed to get home ASAP so I left the car.
01 MKIV GTI ME7 converted hybrid k04
08 MKV GTI Daily driver duties
I have serious VAG issues.
