Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Mk4 gti head unit install, need help!
    Nov 2013
    Does anyone have a wiring chart for what colour wire is what for the existing eurovox harness?
    And will I need an antenna adaptor?
    Sep 2012
    Wonga Park, VIC
    Golf mk4 headunit help - SQ & Technical - Talk Audio
    and yes you'll need an antenna adapter
    Nov 2013
    OK, so i've finally gotten around to taking the head unit out. I'm wondering what these two things are? im pretty sure the thing with the pink and black wires is just to suppress electrical disturbance from alternator and such? But not sure what the first picture is, it looks like its been wired in by a previous owner maybe? it just has a fuse inside it. It appears to be tapped into they yellow wire going into the eurovox head unit which from my research is the amp trigger
    Mk4 gti head unit install, need help!-img_6355[1]-jpgMk4 gti head unit install, need help!-img_6354[1]-jpg
    Sep 2012
    Wonga Park, VIC
    dont remember either of those
    Jul 2007
    Brissy
    Neither of those look like they are original.
    1st is aftermarket fuse older.
    No idea on the 2nd. Take off the foam and look for a part number etc.
    Stock has an ISO connector, follow it back a bit and there is another connector.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Oct 2013
    Eastern Melbourne
    I just ripped out the old deck from the Bora, and even though the headunit was aftermarket, it had nothing like that attached behind it.
    The factory stereo harness' are the Eurovox ones that all aftermarket ISO harnesses use. All you need to do is buy a ISO harness unique to your headunit brand and them its pretty much plug in and play apart from needing to switch the yellow and red wires on the ISO harness. Simple stuff. Easiest headunit wiring install I've ever had to do.
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
