Originally Posted by
TheOt
Fantastic, how do you switch between boost levels and how much? And is limp mode deleted?
The immoboliser is deleted so will work with any mk4 gti. The only way I know of being able to switch is from any Revo tuner dealer they just plug in their laptop and switch over I found this out after getting the immoboliser deleted the tune switched to low boost and I went in and got it switched back.
Revo do sell a SPS Switch which allows you to switch between tunes but as far as I’m aware the Aus delivered mk4 ecu is unable to use it.
2004 Golf GTI MK4 Reflex Silver | Custom Code Phase 2 Tune | Ported K03S | Ported Exhaust Manifold | Silicone TIP | N75J Valve | 2.5" TBE| Silicone Boost Hoses instead of rubber | Turbosmart DV | Unrestricted Pancake Pipe | Cold Air Intake | JOM Extreme Coilovers | Whiteline Rear Sway Bar | DieselGeek Sigma 5 Short Shifter| Driver Side Vent Mounted Boost Gauge
