Results 1 to 7 of 7
Thread: MK4 GTI Dodgy Petrol Gauge
    Mar 2012
    Angry MK4 GTI Dodgy Petrol Gauge
    The petrol gauge is acting up.
    Monday evening I filled the tank up with 98 Octane. After driving the car numerous times the petrol gauge is stuck on full.
    When i got the car i filled it to the brim and never had this problem, this is the second time I've filled it to the brim and now the gauge doesn't like me.
    When I turn the car off it goes to the bottom, so that works fine.
    Today i was driving and was stuck on a hill with traffic and the gauge went to below the top line, as i drove off on level ground it went back up to full.
    I even boosted a fair bit to see if the gauge would move but nothing.
    Hitting the dash did nothing.
    Has this happened to anyone else?
    Or how could this be fixed? As i would like to know how much petrol is in my car.
    Thanks
    Feb 2007
    Somewhere
    Sounds like the fuel sender unit is busted.
    You'll have to remove your rear seats to get to it.
    I believe that the fuel sender unit is separate from the fuel pump and if I'm correct you'll be able to just replace the FSU.
    DIY here: VWVortex.com - DIY: Removal and Reinstallation of Fuel Sending Unit
    MKIV Golf R32
    BMP
    #171 / 200
    Hey Mate,
    you should try the following:
    1 Disconnect the postive and negative cables on the battery
    2 Bridge the cables for ten seconds
    3 reconnect the cables on the battery
    Doing this will reset your instrument cluster, sometimes this is enough to do the trick.
    Hope this helps,
    Cheers Richard.
    Mar 2012
    The gauge slightly works now. It moved down a little bit, but it should be lower. Ill have a look and get a new one i suppose.
    Thanks
    Jul 2007
    Brissy
    How many Km have you traveled since filling up ? I get about 80km before mine moves.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Feb 2010
    Seaforth, NSW
    Quote Originally Posted by JustCruisn View Post
    I can get up to about 130kms before mine moves at all depending on how I drive haha, to the OP just give it a little bit of time and just see if it drops
    2014 Golf GTI PP - Pure White
    Mar 2012
    haven't really checked how many kms. Ill have a suss tomorrow how many i do, and hopefully the gauge budges more
