Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: mk4 gti clutch problem
    Jun 2009
    thanks for the help jmac.
    I ended up going ham on the inside of the bellhousing with a die grinder and took the box back to the mechanics. the box came in and out quite a few times because it was still hitting on clutch fork just slightly and the backing plate was also grinding on the back of the flywheel so it had to be flexed and ground down just a little. but its all working now and im happy with the singlemass clutch.
    if anyone ever needs a bellhousing clearance tool shoot me a message.
    Jan 2014
    how does the single mass flywheel compare to the original? I guess it is most noticeable at low rpm that it is not quite a smooth?
    Jun 2009
    Not quite as smooth but not that big a a difference with normal driving. I havlnt had a chance to drive it hard yet so i cant compare. But over all id say it feels alot "sportier" than the dualmass did
