Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: MK4 GTi bouncy idle
    Jan 2014
    Narangba QLD
    wow. glad to hear its hopefully all sorted !
    Dec 2014
    coopers plains, QLD
    Yeah still good. Might finally be time for some half decent mods!
    Dec 2014
    coopers plains, QLD
    it was going so well
    Came back today, busted out the multimeter
    Pin
    1 4.89v
    2 0.02
    3 0 (no pinout)
    4 4.89
    5 4.94
    6 10.66
    7 0.02
    8 0.01
    Had a look at a few diagrams and cant see which is signal? There is plenty of info for DBW but not so much for DBC
    it was all going so well!
    Dec 2014
    coopers plains, QLD
    May have found a possible culprit
    Screw on this sensor has been tightened so hard that its removed all thread and is just now wobbly
    I have applied some sealant to see if it takes at all
    I'm guessing the only option is to re-thread/tap the hole and use a slightly larger screw?
    Would this area post TB always be under Vacuum? i wondering if its pulling it flush when idle and the pressure changes when gunning it are pushing the plastic out a bit which is causing the weird idle issue
    Attached Thumbnails Attached Thumbnails MK4 GTi bouncy idle-wp_20151023_07_39_56_pro-jpg
