Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: MK4 GTI (1.8T AGU) with an puzzling misfire.
    Apr 2009
    Newcastle NSW
    ^^ what Matt said.
    Had that issue with mine.
    Melbourne, VIC
    There is an ignition control module on the side of the airbox. I keep them in stock if you cant get one out your way. It controls the coils and spark. Common problem.
    I've had a miss fire at idle no codes no change after new plugs. I've been wondering if its the ICM how much do you sell them for?
    Sent from my GT-N7105 using Tapatalk
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
    Camden, Sydney
    $165 BRAND NEW for Ignition Control Module.
    Mar 2014
    Quote Originally Posted by Swainey32 View Post
    I've got same car, same engine.
    Although I don't have an answer for you I can say I had to replace my MAF last year, and my symptoms were engine shutting down whilst driving, inability to start car after this and blowing smoke.
    So I'd assume if you were having MAF issues your symptoms would be somewhat similar as your ecu wouldnt be able to receive accurate data on air flow and would shut it self down to ensure nothing goes wrong, can't see how this would cause a misfire?
    I could be completely off track but though my experiences might help
    Just had this exact issue happen to me this morning, waiting at the traffic lights then engine shut down on me out of the blue. Tried starting it a few times and would shut down straight after soon as it started, so had to tow it to the mechanics.
    They did the diagnosis and came up with a faulty MAF code error. Even tried removing the MAF sensor and started it up and the engine would run ok, at the same time whilst the engine running, we put the MAF sensor back in and the engine would shut down.
    Having a new one fitted tomorrow, hoping that's what the issue is, a faulty MAF.
    Oct 2014
    Vic clayton south
    I also had this problem and replaced my maf
