Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: MK4 GTI 03 blow off valve question
    Jun 2012
    Springfield
    Thanks all for your help! These are all new terms for me lol. Learning a lot.
    I think my best option is to take it to a performance shop and they can also help recommend something. I don't want the car to sound like a twat has done it up, just a little something extra to make it that litte more petite
    Scooter
    Feb 2008
    Yes... A performance shop, where they will charge you tho highest price for little gain... Jump on the Forge Performance website and have a look...
    May 2012
    Mine has a HKS SSQV from previous owner. I may sound a bit noobish but what's a diverted valve? I'm looking at changing to something a little less obvious.
    Dec 2008
    sydney
    Diverter valve recirculates the boost back into the intake when you get off the throttle, like a plumbed back BOV.
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
    Jul 2007
    Brissy
    A lot of people have used the Forge 007 DV.
    It is simple enough DIY, just make sure you have some rubber/silicone tubing for the actuator line (goes at the top) as the original will probably have perished and will break.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Oct 2010
    Melbourne, VIC
    If it seems to run ok now, there's probably no benefit from fitting a recirculating one.
    I thought that recirculating back to the inlet help keep up inlet pressure so that the engine wouldn't fall off boost between upshifts
    Resident grumpy old fart
    Quote Originally Posted by kaanage View Post
    The fall off in boost between shifts, is more down to the build up of pressure behind the throttle plate causing the compressor to slow down, rather than the recirculated boost.
    I always understood the problem with not recirculating back into the inlet, was more to do with the loss of metered air. Causing the ECU to get confused.
    Jan 2009
    blankedy
    The Forge 008 is a nice bit of kit, there are cheaper options.
