Mk4 golf temperature gauge problem
I have recently bought a 2001 golf. driving it home i noticed the temperature gauge never moved off of hard left of the gauge. after searching the internet i decided to change out the sensor but this didnt fix the gauge. again more searching and i started testing the wiring to the sensor. i found i had 5v at one of the terminals which i believe must go to the ECU but didnt get any voltage at the other terminal i believe should have 5v that feeds the temp gauge.
i thought i would test the gauge and just bridge the 5v from one pin too the other just to test if the gauge moves. It doesnt. when doing this it takes the voltage back to only 1-1.5v. So now i'm thinking i have a damaged loom as i'm not getting supply voltage too the sensor and when i bridged i think it went to earth and that is why it dropped the voltage? Someone please correct me if this train of thought is wrong.
i followed the loom back to a connector located under the battery box but was unable to get it apart and was to scared to force it and damage the plug. So my question is, is that the correct connector to test or is there another spot i can check for continuity and voltage for the circuit.
Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
