Jed, I'll check those for you in the morning mate and let you know the story.
Inbox emptied too.
Hey there h100vw, I tried to PM you, but the site says your inbox is full.
HHere are a couple of pictures of my radiator, just to see if it looks the same.
Thanks, Jed.
Inbox emptied too.
pm sent Jed, will separate parts if required
1J0 121 253P is my radiator.
1J0 820 411D for the condenser.
I might have to get a tape measure out for the dimensions.
I took some pictures of the pipe side but still waiting on my phone to upload them.
Great, thanks for that.
Hmm, it's hard to tell from here. The only thing I can really notice is that the electrical plug (left side down near the lower coolant pipe) seems like it's a different shape on the two.
You'll be able to fit yours into this one. They should be the same thread.
The radiator core is 605mm between the crimped ends. The inlet and outlet have 370mm between centres. I also have at least on of the hoses and probably both if I looked. So with them I'd be surprised if you could make it fit.
Is your leaking? You could just take it off and bend it straight if it isn't. That would be free!
I did that with the rad on my Ibiza after it got reversed into.
Unfortunately the actual surrounding area for the pipe has been broken off.
I'll have to let you know about buying the part, as at the moment our view is shifting more towards the possibility of getting another car.
As for this one, we will either try and sell the whole thing for parts or a fixup project, or start to pull it apart ourselves and make as much money as we can towards a new car.
Also, anyone on this forum interested in parts or a full car minus the damaged bits, get in contact with me. When I'm a little more clear about the best options, I may post a separate thread for the car/parts.
Just for a rough idea, everything from the car is available, apart from the damaged parts which is pretty much the hood, latch, radiator, radiator support, a/c compressor and dryer, headlights grille and bumper..
All other body parts, interior trim, engine, mech, etc. is available. If you're interested in the whole thing, just shoot me an offer and I'll take it into consideration.
