My needle sweep test is normal, goes to 100, and I have a feeling that adjusting the impulse value won't be enough, however them gti impulse number is probably them one I am after
Could someone with a mk 4 gti, please give me their instrument code? I have put a 1.8 t into what was a 1.6 without changing the cluster, the end result is a speedo well out of calibration. This is because the cluster codings are different.
from the main menu go to 17 instruments and then to 7 coding and write down the codes please.
One of those is the one. If more than one member could do it then I can be sure of getting the correct one..
Thanks guys
please
Does this help?
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 826 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 07702
79 MK1 GLD
03 MK4 GTI
94 993 Carrera
Didnt get near the car tonight, so not sure, but thanks so much for checking it out, I think that is what I am after
How did you go Stan? I've just noticed my speedo is out after the engine swap too. About 12-15% slower on the speedo than the GPS I think.
Lil' help?
Thanks in advance!!
Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
