Results 1 to 6 of 6
Thread: MK4 Golf 1.6 Automatic 4000rpm @ 100km/h
    Jun 2009
    Melbourne, VIC
    My sister's 1.6 Automatic Golf revs really high on the freeway. We were thinking it was her transmission not shifting into 4th. This is the fault:
    Control Module Part Number: 01M 927 733 LK
    Component and/or Version: AG4 Getriebe 01M 4985
    Software Coding: 00000
    Work Shop Code: WSC 00000
    1 Fault Found:
    00545 - Engine-Transmission Electrical Connection
    31-00 - Open or Short to Ground
    Can anyone help interpret?
    Could this have something to do with it revving high or it's something irrelevant? Also she's gonna take it to VW and pay $126 for a diagnosis.. Could I use VCDS-lite to help her save $$$ ??
    VW Bora V6 4motion
    Aug 2007
    Check your fuses mate, they are on the right hand side of the dash, if you scan the engine it too will have faults. Dont fall into the trap of just checking the auto for faults. The engine faults will steer you to the correct fuse, normally for the lambda probe, just cant remember at this time of night but seen it before, fuse 32 or 43 springs to mind
    Jmac
    Alba European
    Jun 2009
    Melbourne, VIC
    All fuses were checked and only one was blown. This did fix another problem though lol and now her check oil light that was constantly on turned off, and her gear selector display now works.
    VW Bora V6 4motion
    Jun 2009
    Melbourne, VIC
    Basically the mechanic had a look and saw the same fault codes but cleared them, and this fixed the problem. The car now shifts gears. It was supposedly in limp mode and the faults that caused it were electronic. We're not sure when these faults occurred so for now she'll drive around and hopefully it doesn't happen again. If it does then we'll take it back.
    VW Bora V6 4motion
    Aug 2007
    Think you will find it was the fuse i was on about, you have replaced it and cleared the faults, im sure thats it, clearing codes doesnt fix faults but you physically changed a faulty fuse which number you havent mentioned, i know for sure there is one that goes and gives this fault, and yes it all had to be reset.
    All good though
    Jmac
    Alba European
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by Jmac View Post
    All good though
    Jmac
    True! Thanks a lot hopefully it won't stuff up again any time soon
    VW Bora V6 4motion
