Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Mk4 ecu problems
    Aug 2006
    Papua New Guinea
    Are you sure it's the ECU? A misfire can also be caused by a leaky hose or stuck check valve. Just my 2c worth but it might be worth checking for leaks before you go to the trouble of changing out the ECU.
    Greg
    2002 New Beetle Turbo
    Feb 2018
    Melbourne AU
    The latest on it is that the ecu is fine. It's going back to the shop to be checked for dodgy wiring between the computer and coil 1. There's no spark when you unplug it while the car is running as opposed to the other coil packs
    ignition control module on the airbox.
