So finally got around to pulling my brakes off last night, for some strange reason it was only my rear left that had worn out, to the stage that the pad had fallen out and was just caught on the rotor, sitting on the guard at teh bottom, this rotor is absoutley farked, anybody have any idea's as to why only one corner would have worn out, the other side had heaps left and the rotor was like double the thickness !
A (production) racecar I once worked with had a pad separate from its backing plate, which well and truly stuffed one disc, leaving the others fine.
Maybe that's what happened?
Could of been, I think this side still had more wear due to the face both pads were worn out, even the one still in the caliper, seized caliper maybe >
Will both rotor's have to be replaced or is it possible to only replace the one that is worn
Replace them both mate otherwise they will be worn differently. No point cutting corners in the brakes department.
2000 Mk IV GTI
No Worries, Going to go pick up 2 new rotors soon, Got a great price from intervolk $46 each + GST
Alright Nearly All done,
Just had to replace the rear calipers,
Also before I changed all this my ABS light on the dash came on any idea's why ?
also are ABS brakes any diffrent to bleed than normal brakes ?
This is all getting to hard ! off to the workshop next time i think !
- You may not post replies
- You may not edit your posts
Forum Rules
