Originally Posted by
Bug_racer
The rivets on the selector forks were coming loose . Its a common problem on all 02m 02q gearboxes . The fix is to replace the rivets with a nut and bolt .
I feel for you cause you just replaced one gearbox which had the problem with another that will eventually have the same problem !
