Results 31 to 39 of 39
Thread: MK4 Bora 4Motion Tail shaft / Prop Shaft parts
  1. #31
    Jun 2014
    Brisbane, Queensland
    These are for the front. The post and my question is about the rear flex disc.
  2. #32
    Apr 2014
    Penrith, NSW
    Quote Originally Posted by arek_p View Post
    Thanks @beale187 - Febi Bilstein 19528 is 400 pounds plus shipping
    This is the front flex disc.
    Yeah it's pricey but it'll last another 20yrs.
    I've put the call out on the rear flex disc - will let you know if I hear back.
  3. #33
    Jun 2014
    Thanks, I spotted my mistake.
  4. #34
    Jun 2014
    @NAANI?4Motion,
    I'm trying to replace the rear flex disc.
    I've removed the three 12 point 10mm bolts & undone the three 17mm nuts.
    But when I try to unscrew the bolts there doesn't seem enough space between the Haledx to get them out fully. Any tips?
    Attachment 56189
    In your photos, these bolts are shorter and don't seem to have nuts (like the front flex disc I did a while back)
    I found in one of your above diagrams:
    12-point flange bolt #22, 60 Nm
    Modification: From 09.02 onwards. new securing bolts with balancing nuts and washers were introduced for some propshafts
    Two of the new securing bolts might be installed with a balancing nut and washer
    If securing bolts are unscrewed, balancing washer and balancing nut are not allowed to be reinstalled
    I just noticed in your photos, will the rear flex disc come out without taking the prop shaft apart like you did?
  5. #35
    Jun 2014
    I've loosened the 3 bolts which face the back of the car (#22). Not enough room to pull them out fully.
    The car is tilted front down.
    There's some forwards movement of the prop shaft but still can't get the flex disc out over the bushing.
    Also tried a crow bar to push the prop shaft forwards.
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241029_prop5-jpg
  6. #36
    Jun 2014
    in case anyone is doing this, just take out the 4 nuts holding the central exhaust support and the flex disc comes out easily
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241102_prop2-jpg
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241102_prop1-jpg
  7. #37
    Apr 2014
    Penrith, NSW
    great tip mate
  8. #38
    Jun 2014
    Installed the Gen 2 rear giubo on 2003 V6 Bora as first done by @NAANI?4Motion.
    It is 170g heavier than the Gen 1.
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241112_flex5-jpg
    For leverage, I used a cam shaft tool.
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241112_flex2-jpg
    A long 10mm spanner with a neck is very handy for the triple square bolts.
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241112_flex3-jpg
    I needed to indent the heat shield a little just to slide it in place (just used the flex disc itself to push up).
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241112_flex6-jpg
    No vibration when tested at 100 km/h.
    MK4 Bora 4Motion Tail shaft / Prop Shaft parts-20241112_flex1-jpg
    Definitely doable, but very fiddly. The long bolts are a nuisance to deal with because they can only slide out so far before they hit the Haldex controller.
  9. #39
    Apr 2014
    Penrith, NSW
    Ah that's awesome so confirmed the 1K (MK5) flex disc fits then! The MK4 ones are getting impossible to find
