Originally Posted by
NAANI?4Motion
All in and running lads!!!
Firstly, the tailshaft-haldex coupling…it lined up perfect to the tailshaft, BUT….I did have to drill out the three coupling-haldex flange bolt holes, because the quality of China parts just aren’t made to a very high standard of quality and the centres were 0.5mm off and one bolt wouldn’t line up perfectly with the haldex thread. Re drilled the three holes from 10.5mm to 11mm and it went on perfectly.
I also successfully installed a JXB performance centre bearing carrier and confirmed with the owner/operator of JXB (for the first time, no one has tried this yet) that his kit for mk4 R32 (golf) works on a bora 2.8 4motion…and so he will be updating his website and products across the board to now accommodate this chassis in his lineup.
Also, while I was under the car all day, I dropped the rear subframe and also installed a Darkside Developments 50/50 haldex bung and serviced the haldex.
It drives quite differently now and the difference was immediately apparent when hard launching.
I will upload photos later today ✌
